drill/tap for pyro probe?
Old 10-06-2007 | 01:56 PM
Tim Frederick's Avatar
Ive heard that you can do this with the manifold on and the engine running. Is this safe for the turbo? I know 2 people that have done it this way. I have a post-turbo probe, but I want to install a pre-turbo probe. thanks
also, where is the best place to drill the hole?
Old 10-06-2007 | 02:09 PM
2500Ram's Avatar
No problems at all doing it the way your talking about. I started with a small 1/16" hole through the manifold engine not running. Then I started the truck to drill the 5/16" hole with a well greased bit to catch the shavings. Shut off the truck and used a magnetic pen to catch any shaving that fell into the manifold. I didn't find any.
As for placement there is a good diagram but I put it 5/8" back from center on the rear portion of the manifold. I'm sure someone will post the image or just search, it's on here 100's of times.
LovinTheTorque
09-14-2013 12:02 PM
txpig
03-18-2008 02:01 AM
06Cummins
05-23-2006 04:20 PM
G1625S
01-16-2006 12:41 AM
Drafter
05-10-2003 10:51 AM
Quick Reply: drill/tap for pyro probe?
