Dragon fire extreme VP44
Has anyone seen or used the new pump from II. It claims it puts out twice the fuel as the hotrod pump. I have an high output 6 speed and was going to put a standard pump on cause the old one is toast. From what i have read it is not an issue just bolt on and go but now this new pump sounds very interesting.
Yes but with the new pump if you plan on going over 100 mile road trips your going to almost have to have a fuel cooler! Just because if your not using the extra fuel the pump is putting out then its returning it bank to the tank and eventually your fuel will get warm then get cycled back threw the pump warm possibly causing pump problems!
I have never had a problem with the fuel heating up on road trips. its only flowing 140% more when you command it to not constantly at all throttle positions. I dont think it will heat up any more than a regular vp would unless you are real low on fuel in the tank
The injection pump should have the ability to put more fuel into the engine but wouldnt the flow of my walbro 392 be the deciding factor on fuel flow to the injection pump and if not used then returned to tank?
Kman9090
Competition / Pulls / OffRoad
09-05-2009 01:18 PM
TDX
08-24-2009 01:01 AM
Brokenarrow
06-15-2009 12:54 PM
TDX
54
04-12-2009 05:28 PM
