drag racing and trans questions
the other day I was drag racing, I had it in 2wd the first few times, lockup switch on and OD locked out. running down the track I get to the top of 3rd and hit the OD button, and it stays lit. the trans never shifted into OD either. it did this twice. so then I decide to leave the OD button alone. it works great then, but a few times when I ran it in 4wd, it wouldn't shift in to OD either. did I do something wrong or what? it seemed like it would shift into OD if I pushed the transfer case into 2, but there was a time I ran a great run in 4x4 and forgot to push it into 2 and it still went into OD. any one else have this? its the stock trans BTW.
The O/D switch is not shifting because of our tps. Mine freaks out when it wants too. I was just at the track last night and it would let me shift in to o/d two out of the three times I ran. I am pretty sure your tps needs adjusting. I have the same problem. I adjusted mine so it would shift into o/d at full throttle but then my converter lockup is all messed up. Not sure if I will ever win
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
The O/D switch is not shifting because of our tps. Mine freaks out when it wants too. I was just at the track last night and it would let me shift in to o/d two out of the three times I ran. I am pretty sure your tps needs adjusting. I have the same problem. I adjusted mine so it would shift into o/d at full throttle but then my converter lockup is all messed up. Not sure if I will ever win![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
dog rocket
10-16-2007 01:05 PM
Mike D
67
11-01-2006 10:37 PM
genros
18
09-16-2006 08:17 PM
abc4yew
13
07-28-2006 09:47 AM
