Don't know if it can be done
Old 02-12-2006 | 08:53 PM
Bigdually01's Avatar
has anyone used a power programmer and a chip. I got a van aaken smart box and my friend sold his ctd and i got his programmer. Can I use both of them or will i have problems please help thank you
Old 02-12-2006 | 09:32 PM
duallydave's Avatar
Talking
the van akken box adds timing and if the programmer does{probaly does}then you will be adding to much timing which may harm the engine,im pretty sure programers only work with fueling only boxes.
Old 02-13-2006 | 09:07 AM
Ph4tty's Avatar
The programmer should work as a code reader if nothing else.
Old 02-13-2006 | 05:20 PM
Gotlift01's Avatar
As far as I know the programmer doesn't add any timing so you should be ok using it with your box..........I'm not 100% SURE that is true but I remember reading a post from Bob Wagner saying that the programmer didn't add timing.
~Nick
Old 02-13-2006 | 05:45 PM
eric13's Avatar
I have a question. If a programmer doesnt effect timing and only fuel then wouldnt it have to tap into a pump wire somewhere? I ask because I had a superchips tuner and sold it when I got my comp because I was told that would be way to much timing but I know a guy that uses the same setup on his truck but he only uses it at the pulls and sometimes has to give it a shot of ether to get it going because of the timing and it sounds like crap when it finally starts.
Old 02-13-2006 | 05:58 PM
displacedtexan's Avatar
Yeah, you are right Eric, Nick is thinking of the Smarty, which is technically a programmer, but it is in a whole different leauge from the Superchips and hypertech, which are timing based...
So I guess yall are both right...
Old 02-13-2006 | 06:01 PM
eric13's Avatar
Thanks for clearing that up for me. Was always something i wondered about after I sold the superchips,thought I should have kept it but glad i didnt now.
Eric
TayTay
69
05-13-2015 04:42 PM
Totallyrad
07-19-2011 08:41 AM
pwrtripls1
06-06-2010 11:26 AM
mainer
10-23-2007 03:42 PM
Ramdriver15
01-24-2007 10:33 AM
