Don M - Need Advice Before I Order!
So, as my sig. says, i have twins and super mentals. I would like to increase my spool up and pull, so looking to change showerheads. I am a 01 ETH 6speed, 20 over head gasket (head was shaved 6 though) and a HX35/12 - HT3B/23 twin setup. I dont tow at all, my main goal is ultimate street performance. What is the largest EDM injector that i can safley go with?
Thanks!
~Darin
Thanks!
~Darin
how big and what is the difference between a 4 and a 5? i dont want to melt it down in the blink of an eye, but i dont want to regret not going big enough. u think i can hit 550 with the 5's?
DTR Advertiser
550 with 5's? YES
EGT is not cool, with 5's.
Auto trucks with twins hover around 1500 WOT at the highest with 6's and twins.
With 5's, twins and an ETH you should be close to that.
I have NO, ZERO , ZILCH experience with tiwns on the ETH. I feel its safe to assume they will cool things down just about as well as they do on the ETC.
Don~
Don~
im assuming that the auto truck with 6's that you are talking about is nathan's?
thanks for the quick responses - sounds like 5's are going to be good for me
I have an ETH with twins and Mach 6's. I can pull whatever I wanted all day long and have no heat issues. My twins are rather large compared to most though and I do have unique fueling. My EGT's are really low, less than 1400 at WOT. I think 5's are your best choice and I bet you could tow with them if you wanted.
Horace
Horace
DTR Advertiser
Horace
Horace
Ocean front property salesman are everywhere these days
jmccart
08-02-2007 12:35 AM
mdq
12-24-2002 03:29 PM
dealseeker
15
12-17-2002 06:43 AM
