This is for Don M
This is for Don M
Don,
I noticed you are making over 500ponies with a single. Is that a Kwikspool B-1? I know you are not using Bosch injectors to make that power. I am looking for the same results with a single. Please give me the low down on the injectors you are running (hp wise). Also what clutch should I go with? I just recieved my 13-1.25 ofe, but I think I will need to send it back. Should I o-ring my head and get studded, and how much will that cost. I plan on doing everything but the machining. Thanks, everyone else pitch in here. I need your opinions.
DTR Advertiser
Yeah, I have a 12 valve with a large injection pump. Last run was 620HP.
I outgrew the 55 and went a large Garrett. The 55 will fit inside the Garrett for a size reference A 24 valve wont spool this monster without some serious fuel and daily driving will be terrible.
I have not had any time to build any EDM injectors for my truck. I used Marine 370's. Im building some EDM's for it this year sometime.......I hope!!
Don~
Don~
Don~
Don~
You better get yer self some of those EDM's. I hear they are pretty good. Just look at all these threads on them.
Boyd.
Garrett turbo
Don~
Don~
