Does your truck have Load Range "D" tires ??
Old 03-22-2006 | 10:18 AM
  #46
latitud_rt's Avatar
Not entirely true...
Originally Posted by Brock
all tires are not created equally...so all D range tires and even E range tires are not either.
if you get a larger size D rated tire with a load range of over 3000lbs each.....you should be fine for towing anything up to 10,000 pounds. Like others have said...some D tires will flex and feel squishy...but my Nitto Terra Grapplers (295x70x17) feel solid with 60front and 65rear. Tire place put them on as 65 front and 70 rear but I dropped it five pounds...they were going by door sticker for max load.
So the bottom line is there are some great D tires out there especially if you wont tow more than 10,000 pounds...but you got to look and read their load ratings and such. Right now not much choice for our 17inch tires...but hopefully by time I need another set the choices will be larger.
This is not entirely true....ALL LOAD RANGE 'D' and ALL LOAD RANGE 'E' tires, well actually all tires produced to be sold in the USA, must conform to a government regulation standard for loads and inflations know as THE TIRE AND RIM ASSOCIATION OF AMERICA. This publication is used by all tire manufactures to designate load and max inflation pressures (on P-metric and LT-metric tires). Recently, some tire manufactures have begin to fudge the inflation pressures in order to try and increase the load. If this happens they must add additional engraving on the sidewalls to account for the fact that this information is not EXACTLY what is published in the book. Some of the wording may be something like "CANADA USA CODES ONLY" or the like. I can tell you that even if the load rating of a oversized 'D' tire is equal or close to the 'E' rated tire, and you are involved in an accident, you had better have a dang good attorney or you MAY be found at fault. It happens time and time again, and now that the US government is involved and the NHTSA organization is involved, and after the FORD/Brigestone attention, the courts look for tire related information in almost every case. If the placard says 'E', and it does.... then I would highly recommend 'E' as replacements.
As for construction of tires being different from manufacturer to manufacturer...this is true, but they all are tested under the exact same methods and standards required by the government. Some perform better than others, but do you really think for a minute that any manufacturer of any goods are going to provide an exceptionally better product at their cost? It is never gonna happen. There is only a limited number of raw material suppliers in the world for components that go into tires, and Goodyear owns most of them, so all tire manufactures around the world use the same basic components however some use different compounds to achieve the testing results. Bottom line is you will get different wear, different sidewall stiffness, different ride quality, etc...from different manufactured tires, but if you notice there is no wear rating (also known as UTQG..Treadwear,Traction, Temperature) on LOAD RANGE C,D,E tires....there is pretty much no treadlife guarantee for light truck tires because they are used, or misused, in such a wide variety of applications.
Clear as mud...right!
01RAMer
19
09-28-2011 12:25 PM
Buz
07-12-2009 10:54 PM
Firstgenfanatic
04-10-2008 01:24 PM
Roperteacher
10-27-2007 03:40 AM
sakisaki400
23
12-31-2006 11:17 PM
