Does Juice Plug into MAP sensor?
Old 03-01-2007 | 09:42 PM
GCF724's Avatar
I have a question. Does the juice plug into the MAP sensor? If so can you unplug it and blow more smoke? Also does the attitude have a lighted screen?
Old 03-01-2007 | 09:47 PM
ramroamer's Avatar
Yes It does plug into map sensor (you may need an adaptor).An th screen has 3 light options Bright, dim ort no light.
Old 03-02-2007 | 07:19 AM
madhat's Avatar
Administrator/Jarhead
Push the select button when the screen is on the normal view to change the light setting...
Old 03-02-2007 | 12:18 PM
cLAYH's Avatar
The juice has "sub settings" for each power level to adjust teh smoke level. So you can blow smoke with the Juice by cranking up the smoke power level.
Jordan5687
03-12-2007 12:00 AM
CTD01
01-03-2007 11:17 AM
haloman
12-30-2006 12:53 AM
SkyKing56
07-08-2006 04:33 PM
