Does Edge advance the timing ???
Old 07-08-2006 | 02:18 AM
corndog's Avatar
Hey guys I have been reading some conflicting stories about Edge products. I have a 2nd generation cummins (02) and I have the Edge Juice with attitude 125 hp chip and I was wondering if there is a final answer to that question of whether they advance the timing or not. I pull a 36 foot horse trailer and if they do advance the timing , I probably shouldn`t have it turned right up hey?I am a little confused about if advanced timing and pulling is a bad combination. When I pull with it turned up to the 125 setting, my exhaust tempuratures stay under 1000 so am I still in danger of doing damage? 02 1 ton , 4" exhaust , afe intake , 125 hp edge juice with monitor
Old 07-08-2006 | 02:40 AM
Haulin_in_Dixie's Avatar
Yes it advances timing of the injectors, no it won't hurt to pull with advanced timing.
Old 07-08-2006 | 10:38 AM
corndog's Avatar
Thanks! That`s what I needed to know!!
Old 07-08-2006 | 11:18 AM
HOHN's Avatar
Usually..
There's a buffer of retarded timing in the stock software.
This buffer is used up by the Edge boxes. DO NOT ADD ANY MORE TIMING THAN THIS-- this will put you "over the edge" for towing.
There are a couple cases of melted/destroyed engines from heavy towing with excessively advanced timing.
So enjoy your Edge box and tow happily-- but don't add any additional timing at all.
Old 07-08-2006 | 01:51 PM
Ph4tty's Avatar
Thats punny
12-15-2010 01:03 PM
LanceD
15
01-12-2004 06:23 PM
Davidp
03-16-2003 12:40 PM
95ramtough
22
01-29-2003 09:45 AM
Smokin
11-22-2002 10:31 AM
