Does a #10 really make 330/750?
Well with stock timing and a good clutch my buddy churned out 350hp/850lb.ft. on a mustang dyno with all the AFC stuff at FF and the plate at FF... On the same dyno I hope to hit 400hp+ in a few weeks...
IIFC that power rating was flywheel HP with a 215hp pump only according to TST. The power you get will depend on where you put your plate and how set the AFC up. With your 215hp pump and a that plate I think you could get to 300rwhp.
With mine 3/4 foreward and with whats in my sig I hit 34X or whatever it says in my sig on a superflow.
All the way on a dyno dynamics hit 350 and 840 ish.
I have a 96 with a #10 in stock location for now till I get my new clutch then the fun starts. It runs great and it holds for now. You can see what I did in my sig. If you move it up much it will usualy slip. P.S. You will need more air in and out. The stock turbo is good to 36psi.
krazydher
25
04-15-2010 12:37 PM
aggieredneck12
20
06-21-2009 05:05 PM
Dodgezilla
06-11-2004 01:28 PM
