dodgezilla hybrid boost ???
for those of you running the dodgezilla or other hybrid turbos out there, what kind of boost #'s are you seeing???? I just installed the hybird on my truck with a 14cm exhaust housing & with a stock wastegate from my old 12cm housing & a boost elbow (non adjustable) I'm only seeing like 32-35psi. I did notice that when I put the wastegate rod on it just slid right into place where as before I noticed that they're a little harder to hook up, I think that may be the reason I'm getting a little more lag than what it did with the 12cm housing on the hybrid??? I expected a bit more lag, but it's more than just the lag you'd expect from the housing swap alone,I had the rod come loose on my 97' w/a banks exhaust housing & this truck runs alot like the 12-v did w/the wastegate just blowing open freely all teh time, should I try adjusting it up a little tighter & see if it makes it spool any quicker?? or do I need to get a bigger wastegate?? also I may add that I have the hybrid with the 8 blade comp wheel that's supposed to be more tow friendly & spool a little quicker. thanks for any replies, Dusty
JaMan
03-07-2004 06:24 PM
