Do I really have stage 3 injectors?
When I purchased my truck, the guy told me it had stage 3 injectors and now I am starting to wonder. How can I tell? With my comp box off it smokes a little, but not much at all. With my comp on 5X5 I cant hit 1400 degrees EGT until about 7-8 seconds at WOT, yes, the port for the pyro is on the manifold. shouldnt I be running hotter than that? Do I really have stage 3's or was he blowin smoke up my a--
![Roll Eyes (Sarcastic)](https://www.dieseltruckresource.com/forums/images/smilies/rolleyes.gif)
Depends if the turbo is stock or not. What kind of boost are you seeing? I've got roughly stage 2's and with my KSB-1 and 40 psi and the comp on 5x5 with the wire tapped I can only hit 1250-1300* at 117mph.
Sounds about right. With my box on 3x5, going full throttle in 4th gear, I hit about 1100* by the time I have to shift to 5th. (about 70-75mph) I would try a 5x5 full throttle run in 5th, but my clutch would never forgive me
I cant wait till I get my new clutch
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
turbo is stock, I believe it is the HX35 because its a 98.5. Before the wire was tapped the hp was 370 and had about 750tq if I remember correctly. I havent dynoed since the wire tap. I dont have a boost gauge yet, so I unsure of the boost.
Ill have to check the printout again, but Im pretty sure thats what it tested at. Can I upgrade my injectors before a new turbo, or just wait paitently until the wife lets me buy a turbo? What would be a good cheap injector to step up to.
You could get high tech turbo there in SLC to do an upgrade to a hx35/40 for about 6 bones. It will come back to ya looking brand new. I was all
when I got mine back.
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Doubleover
04-21-2006 02:38 AM
052500#1
13
01-06-2006 03:27 PM
