Do I need a boost fooler??
my vp44 died last week so i ordered the HRVp44 from Industrial injection. i took my edge j/a off and sold it a month ago or so so i have no programmer ... do i need a boost fooler or a different box to use this pump?? thanks for the help guys and great site (in my sig says hrvp44 but it just isnt installed yet ) only other mod is 5" exhaust thanks
Chris
Chris
No you shouldn't need a boost fooler to run the pump. Granted your EGT's might get a little warmer since the HRVP adds more fuel but you should be ok. I'd test her out and watch your egts and how well the smoke clears up, that should tell you whether you need more boost and you can go from there.
~Nick
~Nick
Are ya'll talking about a boost elbow??? I dont know if all these are the same or if they are diff... But i have heard of a Wastegate, Boost contoler, Boost elbow, Boost Fooler... Any help would help... lol
Thanks Trapper.
Thanks Trapper.
Wastegate bypasses air around the turbine at a set amount of boost in order to keep boost down. The point in which a wastegate opens can be manipulated with a boost elbow or boost controller. A boost fooler is an electronic device (included in every box but a superchip) which prevents the ecm from throwing p0234 overboost codes and the defueling.
Clear as mud?
Chris
Chris
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
