Do I need bigger injectors
if you want more boost you will need more fuel.by going bigger with your turbo all you are doing is flowing air more efficiantly. with more fuel you will need more air aka boost. when i had just a box and turbo i was seeing 28 psi now with everything in my sig i hit 40. hope that helps a little
Do you have a j-hook or turnbuckle on the wastegate? If not that is your problem. Stock the WG opens at 18 psi and your EJA is fueling past the 18 psi mark to 20 with the fuel.
Edit
You just put on a new turbo but still check on the WG.
Edit
Check for leaks. Pressurize the intake and any leaks will become readily apparent. I use a 4" pvc cap, a cac hose, and an valve stem to check for leaks.
EdmontonCanada
12-21-2010 10:01 AM
boughtadodge
17
06-29-2003 06:28 PM
