do I have to roll the coal
Old 10-04-2013 | 08:26 PM
papajoeky's Avatar
I have a '99 with edge juice, airdog lift pump, bullydog 100hp sticks, and a new hx40. I was wondering if there are any hints for fine tuning my setup but my biggest concern is that I blow black smoke all the time. any moderate pedal pressure blows smoke and when it slides into overdrive it gives a good plume. If I get into it you can't see behind me. I would like to limit the smoke under normal driving. Any help is appreciated.
Old 10-04-2013 | 09:55 PM
Mountaineer's Avatar
yea .Turn the edge down and keep your foot out of it.
Old 10-05-2013 | 01:29 AM
rightwinger's Avatar
X2.....I run my truck on 50/50 WMO and D2, and it doesn't smoke unless I intentionally try to make it. By the way, when you use the term, "roll coal" I automaticly assume you're under the age of 16 because thats the thing these kids seem to be obcessed with around here....ha ha
Old 10-05-2013 | 01:33 AM
dubc2323's Avatar
I have pretty much the same setup but with stock injectors, and mine doesn't smoke even with the edge turned up
Old 10-05-2013 | 07:48 AM
taken5875's Avatar
Doesn't the juice have subsetings like the edge comp? If so you can still run the juice on high if you can adjust the low boost fueling.
Old 11-12-2013 | 01:36 AM
lovinCTD59's Avatar
Check your charged air system for leaks if that checks out ok I'm leaning more toward the bullydog injectors.. I installed a set in a friends truck years ago. Talk about haze, heat and smoke..
Old 11-12-2013 | 09:35 AM
I have the same set up minus the injectors.
I run mine on setting 4 most of the time and only get a little bit of smoke ,until boost builds, on gear shifts [5 speed] under a heavy pedal.
There are 5 different power levels, and each one has a setting for full fuel delivered at 0,5,10,15 and 20 PSI.
If you have it on setting 5 with full fuel delivered at 0 PSI, it will smoke.
The injectors will add to the smokiness as well...
Old 12-21-2013 | 11:23 AM
Mike Holmen's Avatar
The Guru
You probably have soft pop pressure on the injector, lots of outfits just throw on new nozzles and forget about setting/adjusting the pop.
For a VP truck, 300bar is probably the best non-smoke pressure. For more smokey hazy runner go with 260bar.
crossy
09-17-2012 11:37 PM
cromulius
11-22-2009 09:18 PM
stillsmokin
11-30-2005 11:29 PM
Crimedog
01-12-2005 10:28 PM
Quick Reply: do I have to roll the coal
