Do I have an aftermarket turbo???
Old 09-25-2006 | 04:24 PM
JIT's Avatar
JIT
Part 2
OK guys I have spent some time and money and have done the following...
Edge Juice w/Att
Jammer 5's
BHAF
Dual 5" stacks & 4" downpipe
Added Holley blue to assist LP (FP went to 0 at 3/4 throttle)
Im still not sure if I am getting close to my 350+/800lbs Goal yet... or what it will take to get there!?!? I purchased an HX35 from a board member but havent installed it yet. The poor little HY is Taxed and needsa to go. I will be getting some tranny work very soon!
MY latest Question is should I put the HX35 on? Or should I get something bigger?
I figure I may as well mount the HX35 for now untill I get a replacement... probably a set of BD Twins!!! And if I do so I will need new gaskets so... Who has the part numbers for all the gaskets? I will also need the gasket for the exhaust downspout on the back of the exhaust side to the down pipe.
Thanks in advance!
Old 09-25-2006 | 05:16 PM
RowJ's Avatar
Like you said...might as well put the HX-35 on there. If it's a factory HX-35...it's a 12 cm2 turbine housing, and will still be overloaded with your fuel. If it's a 14 cm2 housing...could work pretty well!
You can get the turbo gasket here... http://www.htturbo.com/ ..... or a Dodge dealer. Down pipe should not require anything.
If you tapped the wire on your Juice, and have the Jammer 5's in (not listed in signature)... you should be well over 350 HP!
RJ
Old 09-26-2006 | 07:52 AM
JIT's Avatar
JIT
RJ
Thanks Bro! I figured I was getting close as my Auto is having a hard time putting it down. I am getting all the smoke I want and I know the next step needs to be a Turbo and after that I am sure the tranny will come out. (hopefully in one peice) The plan is for me to spend MY money on the toys... then when the tranny goes I can plead with the wife to help me get my truck "fixed" with a new DTT unit.
rallydriver
10-02-2008 08:52 AM
Robert P
23
03-01-2007 01:21 PM
I PASS GAS
03-16-2006 08:59 AM
SolarYellow05
16
03-03-2006 01:30 AM
tobyw
07-17-2003 01:35 PM
Quick Reply: Do I have an aftermarket turbo???
