diy steering stabalizer
decided to fab up a stabalizer tonight
took about 2 hours
didnt cost much
15 bearing
15 dom tubing
free scrap metal and some time
ill put more time into it after i see how it holds up
still needs ground and trimmed
btw in the pics it seems to be close to the sway bar but it has like 1/8" clearence and it dont rub
took about 2 hours
didnt cost much
15 bearing
15 dom tubing
just a piece of 1" bar
i took a drill and started to drill a 7/8 hole into one side of the bar
that centered it on the nut because the threads stick out a little when the nut is tight on the steering box
then i tacked it and then full weld
the major part is the bearing and i got mine from thebigbearingstore.com
this is the replacement bearing for the one they sell.
http://www.thebigbearingstore.com/se...-Flange/Detail
is the plate that your bearing is mounted on resting against the sway (stabilizer) bar? cant tell from the photo, it looks really close.
i wanted to do this ($180 is tough for a simple weldment and a bearing) but i dont have a welder and neither do my neighbors so i bit the bullet.
what kinda measurements u need?
it not touching the sway bar.....its got like 1/8"
in hindsite i needed to make the extension for the steering shaft like 1/2" longer
that would have given me more clearence for swaybar(not that it matters cause it no touch)but would make easier to install because it would have more play.
