DiPricol Gauges...
DiPricol Gauges...
Hello everyone,
Been looking around for some gauges to put in my truck due to the fact I don't have any. I have been searching around and found some nice gauges on Diesel Truck Performance Parts & Accessories. I am looking at the DiPricol Gauges...60Lbs Boost(once i start putting money into my truck i figure I will need this) and a 30PSI Fuel Pressure Gauge. Being as my truck is pretty much stock I am not worried about my tranny temp or EGT's just yet(soon though). But anyways...The boost gauge comes with the t-fitting, hose, and connectors...the FP gauge doesn't come with anything(no biggy, ill order the parts) but what i am wondering. Is do I need the "DiPricol EGT Pyrometer and Boost or Fuel Pressure Gauge Wiring Harness " to run the LED's on my gauges? or is this only for dimmer control?
Thanks A lot
Dinner
Thanks A lot
Dinner
Anyone
I just don't want to spend the extra $60 or not spend it, and it turns out i didnt, or did need it. And I was also wondering, will the DiPricol Gauges fit in an AutoMeter Pod?
Thanks
Thanks
Do I absolutely need the harness to wire in the LED's? Or does it come with the wiring/buy some for the gauges? I'm guessing I could just wire it into the light switch so they come on with the rest of the lights, and can dim them with the stock switch?
Thanks
Another thing I am wondering..how many of you are running your boost guages from the rubber wastegate hose..or the intake horn?
Thanks..like to know before ordering
Dinner
Dinner
I know, but right now, I cannot afford to also purchase the pyro at this time. I will probably have that within the next month though. I am not too concerned right now being as my truck is stock...for now.
I just ordered DiPricol Boost and Fuel Pressure Gauges...Boost/Fuel Line Kit(the boost already comes with a kit) and the autometer 3 pod...hopefully everything turns out good.
Well I got my two gauges in today and got them installed as well. Here are a couple of pics:
Idle...12.5-13 PSI for FP
Cruising...10.5-11 PSI
WOT...7.5-8 PSI..these are tapped on top of the fuel filter.
Boost goes up to around 15-18PSI(kinda low, but my turbo is old) That is tapped into the intake horn.
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
I agree, with the above statements. The two most important gauges you can buy, even for a stock truck are, in this order, Fuel Gauge and EGT Gauge (pyro). Then maybe a Tranny Temp Gauge, followed by a Boost Gauge.
bauer500
09-06-2004 02:41 PM
HeberRam
06-10-2003 01:00 PM
HeberRam
04-23-2003 02:05 AM
