DiPricol FP Gauge
DiPricol FP Gauge
I am needing to know what all do I need to install this gauge to my FASS. I know there is a FPG port on it. Can I just run the standard 1/8" tubing with a reducer going into the FASS. Or do I need to run a a standard fuel hose. I got this and a 60 psi boost gauge from a buddy that was parting out his truck after he blew the motor. The FP came with a isolator and SS braided line.
Thanks
Thanks
I used a 1/8 nylon-66 tubing and no isolator. Connect it anywhere you can using a reducer, then route it into the cabin. Use quality compression fittings like Swagelok and there will be no leaks even if you have to take it apart and re-assemble for some reason.
53 willys
09-07-2010 10:52 PM
powerstrokin03
12-10-2006 05:38 PM
TJPro351
16
03-30-2006 10:55 PM
CTD2001
21
11-08-2005 09:07 AM
