Difference between Superchips tuner and Edge
What are the differences/advantages to going with a box like the Edge EZ or Comp as compared to going with something like the Superchips max/micro tuner?
Thanks,
~Rob
Thanks,
~Rob
the superchips wins in the cost department, and if you need a code scanner...which with an 02' you won't. the comp can be adjusted on the fly from the drivers seat taking your truck from pansy to mansy and back with the push of a button...having both I can tell you there is no comparison if power is your goal..the comp is king. the superchips hangs around my truck cause I like the speedo correction.
MikeyB
02-07-2006 02:47 PM
razor6
22
01-20-2006 04:43 PM
BigBlue
03-22-2005 07:16 AM
thecatsfan
02-11-2004 02:58 PM
TurboPirate24v
12-31-2003 12:12 PM
