Did I get shafted on a clutch?
I bought a Con O clutch off of a guy on craigs list in Houston. We measured the disc and its only measuring stock at 12.25? From what Ive read on sites and other threads the Con O upgrades to a 13 inch disc. The clutch also has LUK stamped on it? Can someone gimme some insight here? Thanks a bunch y'all!
I bought two of them for my 5spd there were two sizes first time I had the smaller one wich does not require a fly wheel exchange or some one to drill and tap the holes in the old fly wheel the 2nd one was the larger and both of them were luk parts.
Sounds like you got a LUK.
If it were a South Bend it would have numbers engraved into it.
If you do find some numbers on it, call Peter at South Bend to see if he can decipher what you got.
How much did you give for it?
I bought it, slave cylinder, bell housing, pedal, wiring harness for 600 bucks. I needed all of this because I am doing a auto to manual swap this spring. Thanks for the input P.J.
Its got a lot of pad left on it. He said it was used for 5,000 miles and then was taken out due to sellin his old truck. He was gonna put it in his 98 but got a dual disc instead. I will check into them stamped numbers tho. Y'all have helped alot! Thanks!
I dont remember ANY stamped numbers on my Dual Disc from SBC.
Just call Peter in the morning and see what he says. I usually call at night and leave a message for him and it seems he does his call backs before they open.
Haisley uses McLeod hard parts and EEP uses Mitchell hard parts.
My MU 13-1.25 Con FE didn't have Luk on it and neither did the one i put in tonight in my 1st gen MU 13-1.25 Con FE. I think were fine Jeremy. When I'm done with my NV4500 swap ( for the 2nd timepulled the old one out to do the Allison ) and rebuild the motor in my 96' I hope we can start on yours. Are you still coming over tomorrow?
jacobrw1983
01-17-2011 12:11 PM
