Diamond Eye 4in "installed"
Just installed my new 4in Diamond Eye exhaust. Install was straight forward, perfect fit. Good tip I read on here, don't tighten the clamps enough to bend the pipe, until you ride around to make sure everything is right. Sounds, well, quite IMO. Before this new exhaust system, I had the stock muffler removed and straight piped, then just a 4in turn down on the resonator. It sounds stock in the interior, which is great for the long trips. Roll the windows down rolling past a building and you here the exhaust. EGT's are down and when you park and wait for the egt to lower before you shut down the temp drops fast. Here's some pics...
http://s95.photobucket.com/albums/l1...p/Dodge%20Ram/
--Does any one have a pic of the rear muffler hanger location? I removed it when I straight piped and can't remember where it bolts to (lost the bolts, too...do you know the size) the new exhaust seems to be fine so far with out it, but i'd like to put the hanger back for go measurer.
Thanks
Thanks
mossyoak11
0
08-27-2012 06:43 PM
silverbullet02
08-09-2012 03:24 PM
megajoltman
09-17-2008 04:36 PM
