diagram
diagram
Does antone have a wiring diagram for a 47re pcs trans controller ?
A buddy just bought a 99' 2500 4x4 the po swapped a 47re in place of the five speed and only wired half of it. I have been unable to find a specific schematic for a 47RE i would be very greatful for ant=y help thanks !
Cummins Guru
Hope this is of some help.
TRANSMISSION SOLENOID ASSEMBLY (5.2L/5.9L) - BLACK 8 WAY CAV CIRCUIT FUNCTION
1 T16 18RD TRANSMISSION CONTROL RELAY OUTPUT
2 K6 18VT/WT 5V SUPPLY
3 K4 20BK/LB SENSOR GROUND
4 T25 18LG/RD GOVERNOR PRESSURE SENSOR SIGNAL
5 K88 18VT/WT GOVERNOR PRESSURE SOLENOID CONTROL
6 T60 18BR 3-4 SHIFT SOLENOID CONTROL
7 K54 18OR/BK TORQUE CONVERTER CLUTCH SOLENOID CONTROL
8 T34 18GY/BK TRANSMISSION TEMPERATURE SENSOR SIGNAL
Stevenc
11-21-2003 09:05 AM
