Delivery valves with stock injectors?
Old 07-08-2005, 12:37 PM
CTD NUT's Avatar
Originally posted by Bobcat698
I was just told that if I go with bigger DV's with stock injectors, I could ruin my injection pump.. Is this true?
Thanks
Mine has worked fine for just over 50,000 km.......what specifically gets ruined in the P7100?? I only added 370's about 18,000 km ago.
Old 07-08-2005, 12:55 PM
Bobcat698's Avatar
He said it could ruin a pluger.. Because of the increased pressure but nowhere to release it.
I just talked to a few other people and they say that claim is BS
Old 07-08-2005, 01:12 PM
CTD NUT's Avatar
Somebody please correct me if I'm wrong here becasue I'm not a P7100 expert but I don't think the size of the dv will have much of an effect on pressure.....I thought it was the pop-off pressure that is preset at the injector that alters the pressure. Flow is higher on the larger dv because of the increased hole size.....to me, pressure could be higher at the plunger if the fuel has to be pushed through a smaller orfice......even then, I would think these would be very nominal differences in pressure.
191's are only SLIGHTLY larger than stock 181's that are factory equipped on many hp levels of P7100.
I have never heard of anyone having P7100 trouble as the result of larger dv's.
Old 07-08-2005, 02:58 PM
Bobcat698's Avatar
I have the set coming from Scheids. A bit more money but comparable to laser cuts as far as I've heard.
Old 07-25-2005, 06:40 PM
Jeremy Cusick's Avatar
What size DV's came on my '95 1 ton w/ 5 speed?
Old 07-25-2005, 06:59 PM
SHARPMACHINE's Avatar
Jeremy,
You should have 181s in your truck. You should see the same improvements that these folks are talking about. If you decide to do it, let us know.
justmy.002
Old 07-25-2005, 07:58 PM
I think the next thing mine needs is an injector upgrade. Oh, and a clutch! I plan on re-grinding my home ground #10 plate into a #100. Where does the madness end!!!!!!
Old 07-25-2005, 08:09 PM
JKM
JKM's Avatar
If your just looking for a set or injectors to use for cores , check the classifieds, there was a set in there last night.
Old 07-25-2005, 10:02 PM
What would the cores be good for? I was planning on a new set of bosch 330HP marine injectors. Would it be beneficial to get a set for cores?
Old 07-25-2005, 10:07 PM
Bobcat698's Avatar
I need a set of cores to have sent in to get modified.. I can't have the downtime though.
deezeldude
01-01-2008 10:21 PM
mr T
08-17-2006 05:36 AM
Mcmopar
56
11-16-2005 02:33 PM
SHARPMACHINE
08-06-2005 12:33 AM
Eskimo
14
07-30-2004 10:51 PM
Quick Reply: Delivery valves with stock injectors?
