which delivery valves do I want?
I got a 95, from my reading I have a 160HP pump, I would like to get a little more power out of it. My rig is mainly used for towing (8k max) with my mods now I have a little smoke and my EGTs are easy to control and do not go above 1000. I have heard the 191s are too big for towing, should I stick to 181s? what size do I have now? I also saw these http://www.pdrdiesel.com/products/Cu...es-889-35.html anyone run them?
I would like to at least see the power of the stock 215HP pump...
EGTs don't go above 1000°? Your probe must be post turbo? If so that is pushing the limit.
You get lots of opinions on DV sizing. Local pump guy says 181's (215 hp pump) will handle massive fueling.
I believe your pump has 161's and they are a choke point. If you can find someone that has or it swapping DVs in a larger pump you can often get a free set by giving them your cores.
my probe is pre turbo. I can get it above 1000 if i really want to but in my normal towing and driving I dont see temps above that. Ill see if any local guys are taking out some 181s
how fast to do drive man like 40mph at the most?(just kidding) ive never heard of a truck with even just a fuel plate never making it to 1000 degrees.. as for the delivery valves you have other places u could make power considering a 0 plate flows a ton of fuel for only 50hp injectors. how much boost do you run?
