delivery valves
delivery valves
I was just looking at TST'S 370 injectors and they recommend using delivery valves with them. What are they and how do you install them?.They are supposedly worth 40 Hp in the 160 pump, are they worth it?. Is anyone else using them?. I havent heard about them on here before. and the injectors are worth 140 Hp. Will these work with my combo? Iam planning on installing the 3000 gsk kit. I already have a plate which is still to be determined on how big it is(see other post). It will pull 40 lbs boost WOT. It also has a straight pipe and a K&N with a drilled box, and no ring. I will say that my truck is faster than a new powerstuck furd and a duralacks.
Yes, you will need a set of high flow delievery valves for the 160hp p7100 if you want to run the 370's. The 370's will give you approx 65rwhp and the DV's approx 25-30rwhp.
Hey Jughead,
Yeah a set of 191's will help give you some more power. More on bottom end then mid and top end. Basicly the power tapers off some as rpm's go up.
dvs
thanks. i will look into it. really need to move the power up the rpm band a bit. this thing spins tires in high gear like there is no tomorrow. good 9 in. slicks dont want to hold it with 3.21 gear. just looking for high 7s in an 1/8th mi.
