Delivery valve install
I have a set of 181's coming. I assume I have 131's in my stock 160 H.P. pump. When I install the DV's, what kind of power increase can I expect at the rear wheels? 20? 30? or more?
See my sig for details for any other important details.
Thanks,
Ronnie
Thanks,
Ronnie
Are you still running stock injectors? If so, they'll likely be the limiting factor. I wouldn't expect any gain out of the 181's. But it's a good thing to have up front if you do plan to do injectors.
With stock inectors, they made my truck 1/2 second faster through the quarter mile. The 215 injectors also made me 1/2 second faster, so with both of them, my truck ran 1 second better times through the 1/4 with basically the same EGT's as before.
Eric
Eric
you assume correct that you do have 131's. so you should gain around 30hp
smokeum99ta
01-04-2008 08:23 PM
Swamp_Donkey
05-14-2003 10:31 AM
