Defueling even with an Edge EZ???
I am the one who likes black marks remember. Well, seems the Baptist PArking lot needs some new black top in a few areas, and I was playing around. Tried Power Breaking the ole mule, and it acts as if it is defueling until I ease off the break and then back on a few times in progression before it will start to spin-em'
My question is, even with the Edge EZ, will these trucks still defuel until you let off the break?
That is a different defueling.
It is built in to save wear and tear on the transmission.
2000 on up suffer from this disease.
BD makes a module to fix that, problem is you lose your tachometer or speedometer, maybe both?, when you have it active.
I believe it is called the BD Race Anti Defueler.
phox
phox
IMO, all 24v's suffer from some terrible off-idle defueling - my 98.5 does......the Comp helps a bit and injectors help even more but the only thing I have heard that completely eliminates it is the MAD ECM.....it takes the 24v from off-idle defueling to crazy off-idle fueling!
MAD ECM does eliminate defueling. But the timing is very agressive. With Mach 4's and PM3 on full - I can bog down my engine badley at pre boost heavy throttle with too much fuel. Have to roll into it gradually!
The MAD ECM also eliminates top end defueling.
RJ
RJ
Originally posted by Tommy93w350
Are you spinning tires in a Baptist Church parking lot? Shame on you!!!!!!!
The problem is, Satan wont be able to find him for a week thru all that smoke !
For the ones that don't know the whole story, I got caught up in the moment a little while back, and did a couple doughnuts in my church parking lot. Well I felt horrible about it, and proceeded to find a way to clean them up. Got that done, and after that, I just made a joke about burning out in the Baptist parking lot from now on.
Satan don't want me in hell, I got some Holy Water for his butt. I'll pray for him while I pee on him.
sheriffav8r
02-18-2010 04:29 PM
