DD3's...which box to get?
ok i am lookign to get some dd3's real soon, they are about 100hp versions, my question is which box to go with, i know i wont get as much power but I don't want to tap my wire just yet.
The thing im looking at is an Edge EZ with the 100hp injectors...will this combination work being that my turbo is now at a point where its running 34psi with no fueling mods and so far my highest EGT is reading just under 1200 pre-turbo...but thats only on a long WOT run down the highway
here is what i wanna run
dd3's
Edge EZ
stock turbo with banks big head wastegate (currently peaks at 34psi)
and everything else you can see in the signature
i am only looking for maybe a little over 300hp/700tq, ill be getting a SBC con ofe soon too
dd3's
Edge EZ
the real ? is do you want to tap the pump wire or not if it was me i would buy the edge comp and run it un tapped until you get a good clutch in there and then if your heart so desires more power tap that wire . chances are that your pump will live threw a wire tap .
i am already throwing the 0216 code...but i have not had any throttle stutter issues since resetting the APPS...im gonna run untapped until i can afford a new hot rod VP44
as a matter of fact my truck was previously tapped as scott from renegade diesel was looking at it, he found the pig tail still tapped where they had removed the box before trading the truck in.
i may just tap the wire and see how long the pump lasts...if it dies, ill drive the beater until i get the $$$ for a pump
wow...i never thought it would be so much power with the wire untapped on a stock turbo
now i just gotta find a deal on a comp and skip the EZ
oh yeah and see if i can get that SBC Con ofe soon!
The clutch seems to be fine so far. I am not real hard on it, little bursts around town and some 5th-6th gear runs once in awhile. I realize a clutch is in my future, but I am having good luck so far. With the amount of mods the previous owner had done, I wouldn't be surprised to see an aftermarket clutch in their also, but I doubt it. good luck with your injectors, post results when you get them in.
Here is the big question....How is my truck going to run with the injectors, but no box yet...I am part of Poor Boy Racing (PBR) so i build on a budget in steps...I will be installing the injectors and running them for maybe as long as 2 months before I get the box
I am going to have to take it easy on the clutch which I should be doing anyway and I assume there is going to be a little smoke with the 115hp injectors!
