Dana 80 rear options
track-lok here...no oblong hole
it broke on this pull, but it has always worked great in the fact that i never had a 1 tire fire when playing around or launching.
If I replace the carrier with an entire new unit and have the bearings pressed on etc, will I need to have the rear set-up again or is that only with new R&P gears?
You will need to set it up again. The old settings give you a starting point but I've probably set up 10 or 15 gear sets and no two carriers were exactly the same. Very important... don't take shortcuts on the setup. If you are close but not on the gearsets will probably be quiet enough so you think they are ok but will be weak and have a much shorter lifespan! Good Luck
Firstgenfanatic
09-16-2010 01:37 AM
RichN
0
08-06-2010 06:52 PM
Rattletrap1
04-10-2009 03:55 PM
Bobcat698
11-07-2006 02:42 AM
