D25 coil ?
Old 04-03-2005, 12:44 AM
northslope's Avatar
"Yes, I own D25s. Yes, I could have done better for my money. Yes, I feel purchasing them was a mistake, as other springs are higher quality and/or better value. The Kore springs represent much higher quality. CSS makes great springs, and imho they are worth the modest price premium. I, too, am on a budget."
IN your opinion MY opinion I like D25's. Great I'm glad you like your KOre's wonderful I like D25's, case solved
Old 04-03-2005, 04:42 PM
Kevins's Avatar
I put these on, they are GREAT
http://customsuspension.com/store/pr...roducts_id=753
Old 04-03-2005, 09:13 PM
caper's Avatar
Hey kevins just got those springs havent put them in yet ,the dude told me ya have to grind the spring so it will go in the spring seat???? Is this true?? Man are they heavy , how was the install and ride?? Thanks
Old 04-03-2005, 09:43 PM
kevellis32's Avatar
yes you definetly will, i just had mine installed this weekend with some 315's and the allignement was horrid once i was done...they look frikkin sweet though, i will post some pictures shortly
Old 04-03-2005, 11:32 PM
taken5875's Avatar
any one know what size shim you need for 3'' leafs i have slite vibration under 15mph (rear shaft vibration)
Old 04-04-2005, 12:51 PM
Cowhand's Avatar
1/2" should be plenty. Check your center support bearing while you're at it, if it's worn out it will cause the driveline to deflect and vibrate when you take off.
Old 04-04-2005, 02:07 PM
HOHN's Avatar
Fair enough. Thanks for being reasonable and giving me the benefit of the doubt.
jlh
Old 04-04-2005, 07:00 PM
taken5875's Avatar
thanks cowhand i ordered a carrier bearing drop kit the owner of the 4x4 shop said to try this first any opinnion.. any one
Old 04-04-2005, 07:57 PM
Cowhand's Avatar
How much did it cost you? How thick is the shim?
As long as the center support bearing is still good, you should be all set.
Old 04-05-2005, 07:41 PM
taken5875's Avatar
not sure i was in a hurry and just told them to order it i'll let you know when it's in
1ST GEN.
07-18-2006 12:02 PM
MARKY MARK
13
06-27-2003 05:50 PM
dingo
03-22-2003 01:38 AM
MARKY MARK
03-16-2003 10:32 PM
MARKY MARK
03-02-2003 09:12 AM
Quick Reply: D25 coil ?
