Cutting out after Superchip install
Old 05-10-2006 | 09:50 PM
ramman21921's Avatar
Just installed Superchips tuner today and truck does not cut out at full throttle but when accelerating at 1/4 pedal will cut out and come back at about 2200 rpm's. What would cause this? Also I have not installed a Pyro yet but I am running on safe tow mode and not running hard should I be concerned with temps. I have an infrared temp gauge what would be difference between internal and external temp reads on pipe 6" below turbo?
Old 05-10-2006 | 09:59 PM
Turbinator's Avatar
Better check your lift & injection fuel pumps.. mine stuttered because of bad lp
Old 05-10-2006 | 10:37 PM
Just had a new lift pump installed about 2 years ago had a cold leak on a 8 degree morning. Truck only has 54,000 miles.
Old 05-10-2006 | 10:43 PM
oestreich84's Avatar
I had a stock replacement pump go out in about 20 minutes of driving. You never know how long the stock pumps will last. That is why I now have a Holley pusher pump. I also had a stumble that was caused by low fuel pressure. After I installed the Holley, it went away. You could also try to reset the APPS. There are instructions in the tech facts area at the top of the page.
Old 05-10-2006 | 11:04 PM
displacedtexan's Avatar
I'd use the Superchips to check for codes. And hope you don't have an 0126.
Mileage dosen't seem to matter much with the Carter/VP-44 failures. Unfortunately.
nickpay
10-10-2005 08:58 AM
Cruzer75
01-19-2004 09:25 AM
Jewel
02-05-2003 06:24 AM
