Cutting 3rd Gen Center Caps for H2's
Old 09-28-2007 | 09:26 AM
Txwelder's Avatar
I know there is info about how to do this but I cannot find it. Can someone point me in the right direction. I dont want to spend money on more lug nuts and I am not breaking these things down again to put back on the mill. Just want to know exactly what I need to do to get them on the truck through the cutting method. Thanks.
Old 09-28-2007 | 01:19 PM
Nonstop's Avatar
I used a dremel with a carbide tip. Removed about an inch. I wrapped tape around the cap for a guide and took my time. It's not factory straight, but once I got them to fit I don't notice. The tabs have to be cut to, i think i cut 4 off of each one and trimmed the edges so they would set flush when they go on. I just remembered I had to trim or sand down the back side of the "ram head" because it hit my axle, on the rear ones.
Hope this helps...
Edit: here's some pics
http://s95.photobucket.com/albums/l1...p/Dodge%20Ram/
Old 09-28-2007 | 03:07 PM
westexhunt's Avatar
Table saw
I have done a few sets on the table saw, a little dangerous but I grew up in a cabinet shop and am pretty comfortable with it. I used stock Dodge luguts too.
Old 09-28-2007 | 04:17 PM
MedicShawn's Avatar
I thought you cut off 3/4 of an inch off. I just used a Dremel with a cut off wheel.
Old 09-28-2007 | 08:07 PM
bostiguy's Avatar
This is the info I used: http://www.getdieselpower.com/my04do...h2install.html
Tejas TJ
16
03-21-2011 12:56 AM
rsscoggins
01-11-2011 11:41 AM
b4black
06-16-2010 05:18 PM
j-dubya
0
09-04-2006 06:38 PM
