Custom crankcase vent, COMPLETE!!
Thanks to Mopar1973man, I just finish the custom crankcase vent relocation. But I have two questions, I painted the pvc with some cheap black spray paint. Should I be worried that I didn't use some high temperature paint? Also I was experiencing some high temperatures while towing in the mountains. How do I check if the fan clutch is good or bad from the oil on it? Thanks again!!
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
don't worry about the paint. i just used krylon indoor/outdoor black paint. bout 3 months and all is good!
sorry i don't have an answer about the fan clutch.
If it's the silicone coupling fluid - the more the spill, the less hookup when the thermo-coil diverts the flow into the fluid-coupling channels..
Also check for 'crunchy' bearing action, or if the shaft wobbles in the clutch body - it's shot.
