Custom airbox mod.....Whatcha think?
Ok so i'm thinkin of cutting a majority of the plastic from the stock box....I will layout and cut under the filter, along the sides and possibly the bottom.
Then i will epoxy in this sweet S/S mesh we have at work....This stuff is strong enough to keep the structual integrity of the box....
I figure i can pull just as much air i kniw it will be warmer, but it should work ok........
Oh yea theres already a K+N dropin to......
Should i or not?
Plus gonna bendup a heat shield/water deflector to go around the 3 sides.......
Should i or not?
Like............?
I know someone mentioned a bigA@@ Napa jammie but noone had the part #.......
Plus i'm cheap and i cant see how all the aftermarket filters will jam any more air in the turbo when the feed hose remains the same diam....?
Cheap to the sense that i fab all my own stuff......
click search, type bhaf part number, and:
https://www.dieseltruckresource.com/...af+part+number
that's your freebie!
Forrest..........I dont really see a bigger turbo anytime soon......My trans has got to be done first.
Probably a set of DD2's or something like that...
If your filter minder isn't pulling down you don't need more holes in your airbox.
I hole sawed a 3.5'' hole on the rear of my airbox and another in the firewall, hooked them together with 4'' RV dump hose. Poor man's Scotty. Cool outside air rather than underhood hot air.
