Curiosity
Curiosity
My 2001 dodge cummins came stock with 235hp at the motor and I put 150 hp injectors and an edge comp box on it. Witch was suppose to give it 120hp does this mean it will have close to 505hp if so how much should it have at the wheels?
The numbers are usually rated individually. 150hp injectors 'may' add 150hp to a stock engine. But since the comp box is already adding fuel, the injectors really arent adding 150hp fuel.
If that makes sense.
Id guess you to have low 400's w/ all.
I have the same, ill be dynoing shortly so ill let you know.
Getblown put down around 450 with the comp and 150 hp injectors at spring fling. You'll need a clutch and a turbo to get the most out of these mods.
HO Motor (6 speed) vs SO Motor will make a difference on how much HP you get out of your Edge Comp. Fill in Signature (under User CP) so we have enough info to answer you more accurately
RJ
i made 370hp (245hp stock) with just the 150 hp dyno-mite diesel injectors for fuel. (i had 4" exhaust, and an AFE intake with the HX55 for air).
when looking at drive train loss, a stock truck will dyno around 190hp, so with the injectors and some air i picked up 180hp at the wheels
i know DDP and F1 injectors will give the claimed power, but the bully dog and Diesel dynamics are going to be a little lower then the rating from what ive read.
There are 150 hp Injectors.... and then there are 150 hp Injectors. The F-1, Mach 4's are the only ones I'm aware of that will add 150 hp at the rear wheels.
RJ
RJ
This was actually an assumption on my part.... based on the FACT that they do not get as much from a TST fueling box as an SO engine. I can see no reason why other fueling boxes would perform differently?
RJ
RJ
That 120 hp rating is under ideal conditions.
The TST on most automatics is only good for around 105 HP..... on an HO I have seen 85 - 95 HP. Weather an Edge Comp or a TST... still a nice gain... especially on top of injectors.
RJ
RJ
so should i start looking at injectors instead of a smarty for the next go-go?
simply put...yes. the smarty is an awesome tool, but being you already have a fueling box, id get some 90-100hp injectors next. that will put you close to the max of your clutch. but stacking 2 electronic devices ons tock injectors will strain the injector pump. opening up with some bigger injectors will help take the strain off the pump.
