cummins SUPERCHARGER
i thought people were saying on a thread 2 days ago about how you could not run a supercharger on a diesel? well i just found this in the members section and it looks like an actual kit and not just something someone put together. what do you guys thinK?
Jake
Grunt
The old two stroke detroit diesels were all supercharged. It was the only way for them to get air flow (at all) and scavenge the cylinders properly. Later when they added the turbos to them, and the engine speed got high enough that the turbo was out flowing the supercharger, the turbo would flow around the supercharger. I can believe the bottom end must be through the roof on that thing. They probably geared it to make 15+ lbs boost at idle.
Originally Posted by derek840378
turbos are WAY more efficient on a diesel
Rusty
Lane440 (01-01-2024)
The supercharger idea was to help with the turbo lag.......instant boost off the line and then upper to mid range is when the turbo was supposed to do it's thing......been kinda cool if it worked!!
Could you imagine having the whine from the supercharger and then the whine from the turbo............ahhhhh that'd be the life!!
~Nick
~Nick
the supercharger gets in the way of intake air at higher rpms. if you could have a supercharger and turbo w/ a way to bypass the supercharger at a certain rpm, that would be the cats meow
Rusty
Originally Posted by Charlie8301
I can't find the thread that went with this pic but I think it was making 10 psi at idle and 90ish at wot
Randy
Randy
that thing is realy EDIT off looking!! absolutly awsome..
YEah older detroits were supercharged, and so are EMD engines in locomotives. They actually refer to it as a Roots Blower. On the EMD's they are geared to the engine. All an EMD is, is a very large screamin Detroit, and its 2 stroke too! At work we refer to them as blowers or superchargers.
BMW has a Turbo Kit that they offer on the Mini Cooper that bolts in with the Factory Super Charger. This takes power to 345hp at the wheels!!!!!! This is used like a Twin Set-up on our Cummins. The seperate chargers compound the air to make the total package more efficient. The stock Mini S makes around 140hp to the wheels.
Rusty
