Cracked Flexplate Symptoms
Old 03-08-2007 | 09:56 AM
Cspotrun's Avatar
Ok, I think I have this narrowed down but would like to get some input from those that have had a cracked flexplate.
From a standing stop, as I easy into the throttle I get a pretty good vibration that seems to be coming from the passengerside front wheel. It stops at about 20 mph. After that it drives just like normal. I also get a pretty good vibration as I come to a stop.
Things I've checked:
- Both front hubs. They are tight and have no play in them. Also sound normal as I turn them.
- All the tranny bolts on the bell housing.
- Transmission/TC mount. My last one was cracked this one is only 6 months/20,000 miles old.
Anyone know how to check this without pulling the tranny. Also is a billet flex plate really worth the money. Truck now has 178k on it and I'm fairly sure the flex plate is original. GB tranny was put in at 155k. All opinions and ideas are welcomed.
Old 03-08-2007 | 03:08 PM
kawi600's Avatar
Id check the wheel bearing units, the ujoints and the pinion bearings too.
Does this vibration change with respect to RPM or with respect to speed? That would give you the clue about the flexplate or not.
Old 03-09-2007 | 11:40 AM
Cspotrun's Avatar
Bump to the top... Anyone got any Ideas.
Old 03-09-2007 | 12:06 PM
Redline Ram's Avatar
hold the brake with it in gear and torque it up see if you feel the vibration then.
Old 03-09-2007 | 02:03 PM
dzlfarmboy's Avatar
That or what about when you just free rev it up?
Old 03-09-2007 | 02:15 PM
Teddy Bear's Avatar
I seriously doubt that you have a cracked flex plate but i could be wrong. After seeing how weak the stock flexplates look i cant imagine them holding up to any sort of power if part of it was cracked.
Old 03-09-2007 | 05:13 PM
BigBlue's Avatar
You should be able to pull the inspection cover off of the bottom of the trans and shine a light up in there to see.
roccoboost
03-23-2010 09:04 PM
klx650a2
04-20-2009 06:25 PM
Spooler
33
10-15-2008 05:47 PM
Jetpilot
03-26-2003 12:09 PM
WVPANHANDLER
02-01-2003 09:23 PM
Quick Reply: Cracked Flexplate Symptoms
