Couldn't come at a worse time!! Headgasket!!
Well Im pretty sure I blew it tonight. Im too mad to go do further investigation. Ill check it out in the mornin. I never even got on it all night so Im not sure when it let loose but I noticed it kept overheating bad then i get home look under the truck and yep shes a gushin. so I just parked it by the shop and came in.
This sucks how much should it cost for a thicker gasket and a set of studs? Im trying to do it low cost because I just spent all my money on a full goerends tranny. Which isnt even here yet so ill get to install it and not get the pleasure of driving it right away. This isnt the Christmas present I was hoping for.
That sucks man. IIRC, the studs are like $400 for the set of 12mm. I hope I'm wrong. It musta been from the timing and injectors. 200k+ miles is a lot of miles on a stock headgasket. Did you ever get the leak in the injectors fixed?
Yea I fixed the leak the next day. What happened was one of the collars wasnt tight and it was allowing combustion back up out the hole. Yea Im just wondering if we got the timing set correctly. Also could just be that its got 240k on it and the PO ran it hard very hard and put her up wet. Luckily the truck was stock when he had it or who knows what he would have blown up.
My son was using my truck a few Saturdays ago. Says he took it easy all night . On his way home the heat gauge started to peg out. He stopped on the side of road for a few minutes and all cooled off. Never heated up again. It was the thermostat sticking, Maybe you'll be lucky.
Merry Christmas to everyone.
Gene
Gene
That sucks man!!!
I'm watching my gauges with these twins now...I can hit 55psi like nothing I don't really want to pull the head yet, need to install the studs I've got on the shelf!
Good Luck, I hope you're wrong and it's something simple
Chris
Chris
Gene
Gene
New tranny going in and can't take it for a test drive. Real bummer!
As you probably know...Gunracer1 recently had the same problem. Talk to him about the where & how much. I'm sure he found a good buy somewhere.
Checked around the cylinder head yet?
Good luck
RJ
Good luck
RJ
Tore it apart tonight this is where it let go at in between #1 and #2. Look on bright side of things i was gonna have to do it sometime or another with twins in my future. Plus ill get to do a little porting on it. My best guess is that the timing is wayyy too advanced Jb wasnt sure that it was right and my guess is its somewhere in the high 30's range ill find out soon enough though.
