Cost to resurface flywheel?
I'm getting a clutch installed at a local reputable shop that is slow on work so they quoted me 365 bucks for the work. At that price, I can't justify doing the work myself.
Has anyone installed a new clutch without resurfacing the flywheel? My current 13" clutch works fine, it just slips at the track in 4th and 5th.
If they try to hit me with a 150 dollar charge to resurface the flywheel, I want to be able to logically respond. How much should it cost to resurface a flywheel?
Thanks....
I'll do that just as soon as this free warranty clutch burns up. By tomorrow we will know the problem, for all I know, the rear main is leaking. Nobody's clutch will hold up to a leaky rear main.
No oil contamination, just too much torque for an organic 13" clutch. The spring hub has some serious wear and tear. The clutch facings looked good but the flywheel had a .010" deep groove from the old clutch, machine shop had to remove about .013" to get it looking good again.
The old pressure plate looks like it held up much better than the flywheel.
Does anyone know if the 6 speed flywheels are softer than the 5 speed flywheels. My mechanic had never seen a clutch disk eat into a flywheel like that in his entire 30+ years.
Not to bash Valair, but has anyone seen springs do this in 25-30K miles. I know they now make an upgraded spring hub with extra springs. I'm not sure the springs would have outlived the facings.
You really can't expect anything more from a Valair clutch.
Call Peter at Southbend and ask Him how the Valair Plate looked when he tested one for strength
Now you know why they are so cheap
kinda sucks for valair because when I searched I read your post about them...you were kind of like their unofficial spokes person and just about had my mind made up to purchase one and then I decided just to give Peter a call and pick his brain about which clutch he would recommend if I were to go with a SB. The DTR price is really nice! At that point, with all the positive feedback they get, it was a no brainer for me.
with all the kind words you have said about them, hopefully they take care of you BIG TIME!!
tristan21
05-04-2008 04:31 PM
Muzzy
03-11-2005 10:02 PM
