Copper 24v Head Gaskets.....
Anybody know where I can get a copper head gasket for a 24v? Have had several stock and marine gaskets that have been blown.... Has ARP studs and head has been milled and checked for warpage....thanks....
the copper gaskets will leak coolant. the common rail has a factory mls gasket, and it seems to be very tough, you may take a look at your stack and take into consideration the timing your running? im not a cr guy.
if not you could go to a fire ring setup, or go to 14mm head studs
justinp20012500
45
03-22-2005 12:24 PM
