compression ratio?
Old 01-29-2009, 04:25 PM
Haulin_in_Dixie's Avatar
My '97 starts OK not plugged in with old batteries and cycling the heaters three times, down to like 15 degrees. Thats Fahrenheit Scottie
The old Detroit's lost starting ability in the cold when they went to turbos. Lower compression ratio but higher cylinder pressure.
Old 01-29-2009, 04:31 PM
Brokenarrow's Avatar
Uh urs starts at 14.1 because you have a CR! Not a 2nd gen! My Brother is at 15.1 on his CR and starts no problem!
Old 01-29-2009, 04:34 PM
Rpainter's Avatar
Originally Posted by John_P
Boy, I wish my 96' would do that Robert! Any temperatures below around 40 degrees and if my 96' is NOT plugged in, I have a hard time starting it unless I use ether. But,.....I am also running Scheid's Forged Arias Pistons and that may add to it.
However, in December I was up in Illinois and the overnight temperature got down to 3 degrees above zero! I had the 96' plugged in at the hotel and the following morning the truck started on the first try. So,....I try to keep that baby plugged in when it gets cold!
John_P
it started but the neighbor was NOT happy about it starting somehow the white smoke kinda blew over towards his house and I guess his central air unit sucked the unburnt diesel smoke into his house priceless. he said his entire house smelled like diesel fuel... Rob
Old 01-30-2009, 11:33 AM
John_P's Avatar
DOH!!!!
Yeah, I hear you on ALL that Robert! Fortunately for me, I live WAY back in the woods far away from any other houses, so when I roll the old 96' out of the garage on cold days that is one thing I don't have to worry about! Even with my truck being plugged in, it will still blue smoke pretty good until it warms up. I can knock down some of that blue smoke if I add pure cetane to the fuel with some "Stanadyne Lubricity Formula" and their "Performance Formula."
Good story.....................
John_P
Old 01-30-2009, 12:52 PM
Ok, now take a 12 valve, like my '97, run it on half drain oil, and start it on a 30 degree morning...... Yes, blue smoke!
roadgeneral
03-11-2008 05:58 PM
running4bhs
06-11-2005 11:14 PM
kingofdodge7131
11-24-2003 12:16 PM
geof
11-16-2003 07:20 AM
SjLingenfelter
06-30-2003 01:35 PM
Quick Reply: compression ratio?
