complete injector or nozzles
i am looking to see about injectors for my truck and was looking at the jammer stage 1 nozzles. would this be a good route to go since my injectors are in good condition now or should i buy complete ones. I will be running a edge attitude as a programmer
I have jammer 2 (75hp) and would not go any lower, the jammers have been good so far, Ive put over 20,000$ in fuel thru them so far, I had EGT issues, mostly because of the HY turbo (tooo small) I swapped them out for Vulcan Fireball, and I'm not happy with the Fireball, so likely I'll put the jammers back in, that being said there are way better injectors out there. here is a link of all you want to know about injectors, it will help you on your decision.
some guys just put on nossels wiithout having them tested, I think thats a bad idea as if one injector is off it can cause serious engine issues, what ever you get just make sure they are have been pop tested and are within in allowable spec's to each other
http://www.cumminsforum.com/forum/98...ever-want.html
thanks for the real ife info. my truck is running about 800 degree pre turbo going down the highway about 55-60 mph. thats a stock truck with an hx35. Does that seem right?
I have the Jammer Stage4's and for the money I would do it again. With mods in my sig I can hit 1600+ on EGT's, but that is for short bursts. I also run about 750-800 on the highway. Best bang for the buck. They are cheap enough to start with too, so you can see if you want more in the future.
dodge_24
08-30-2009 08:50 PM
Valv
10-09-2008 08:11 PM
Amish hauler
02-22-2004 09:42 PM
