comp smarty stack not working
Old 03-25-2007 | 11:36 PM
bignastydodge's Avatar
I have a edge comp and smarty stack the two will not work together.the smaty seems to be working fine but when i replaced the edge juice will the comp it does not seem to have as much power.It pulls hard right at first then not at top like the comp should. Does not seem to be working past level1 wire is tapped good.
Thanks for any help
Old 03-26-2007 | 12:46 AM
Ph4tty's Avatar
Is it a drag comp?
Old 03-26-2007 | 08:39 AM
displacedtexan's Avatar
Is the Comp used? Could the comp itself be bad?
Old 03-27-2007 | 01:46 PM
No it is a comp box and it was brand new
Old 03-27-2007 | 02:07 PM
Big Smoky's Avatar
Did you ever try updating the Smarty? Try checking for codes. Thats really weird whats going on with your truck. Did you park you truck to close to the maroon truck one day maybe?! lol
Old 03-27-2007 | 10:20 PM
That is true it rub off the bad luck. I talked to creed he said that his friend was running a comp and smarty and had the same problems. He said when he had it update to a drag comp it work alot better. Also the injectors are alot smoother than the old ones little more power not like yours. I also talked to the owner of mads electronics and he said mine is the dated one and the software on yours is wierd it should be 1.07 and 1.20 instead of 2.07 maybe that explains 566 hp and 1800 ex temp Lol. He said that it sounds like 03 programming.
Old 03-28-2007 | 12:50 PM
DMcPherson's Avatar
does it go ok with just the smarty? I had issues when I had one and the truck wouldent fuel ofer 1/8 throttle. I thought my comp was bad
Old 03-28-2007 | 03:05 PM
Yeah it works great with the smarty only and It does cut the fuel after 1/8 throttle. It runs great if you only give it 1/8 pedal than after it falls on its face. Did you figure out the problem on yours I am sending in my box to get it looked at and upgraded to a drag comp it is supposed to work better with the smarty. The drag comp fuels differnt than the regular comp.
Old 03-28-2007 | 03:54 PM
Tate's Avatar
Have you tried removing the Smarty and running the comp alone? What software are you running?
Old 03-29-2007 | 08:36 PM
Yes they work great seperate but not together the smarty has the 1.20 and 1.07 software that is suppose to be the newest.
Sleigher
05-04-2017 03:12 PM
dodgediesel
07-27-2007 09:59 AM
Awall
16
01-01-2007 06:22 PM
S.Dodge
11-25-2006 12:00 AM
jlarmour
11-22-2006 10:19 PM
