comp question
comp question
Ok, here goes: I was saving to buy a Fass fuel with the low fp. light, when this deal came along that couldn't be passed up. A nearly brand new comp box approx. 3 months of use for $ 450.00. At this time I have no way to monitor fp. So now you can guess the question, what level (if any) is ok to run on. It'll a month or so till I get the fass. does any one think this is a bad idea i realy do kave self control
thanks in advance
thanks in advance
Administrator / Scooter Bum
Hook it up leaving the pump tap wire disconnected.
It will act like an Edge EZ giving you nice 60HP & 180TQ kick in the pants increase until you can install a FP gauge.
You will want to give serious thought to a trans upgrade also as you can toast it pretty easily with the added Comp-Level power increase.
you will make it pretty good without the comp tapped.....but tap in and you will spend big money on a trans....Some suggest just a tc and a valve body, I am just gonna run it until it starts acting up then rebuild the whole trans.
taken5875
04-04-2008 12:48 AM
rockjeep73
03-25-2005 03:34 AM
hellotbone
07-12-2003 12:58 AM
hellotbone
18
05-16-2003 04:40 PM
