comp or pm3??????
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:comp or pm3??????
[quote author=PourinDiesel link=board=7;threadid=6519;start=0#61417 date=1036368947]<br>Rob,<br>I dont think so, if they can do 9* why not more??<br>[/quote]<br><br>Under light to mid throttle, the TST box does advance timing to 9 degrees in order to gain some fuel economy, versus simply dumping fuel into the engine. Under WOT conditions, another circuit opens up in the box, and timing advance falls to 1 - 2 degrees.<br><br>As for why only 9 degrees, its a design philosophy. More timing advance, the more likely you are to blow a head gasket. So TST prefers to make most of its power with fuel, versus advance to help keep the head gasket glued together.<br><br>Rod
dodgediesel
14
12-14-2006 10:54 AM
dodgediesel
24
10-25-2006 05:40 PM
rockjeep73
03-25-2005 04:34 AM
joefarmer
20
12-11-2004 06:25 AM
