Comp or Juice?
Old 04-02-2006, 12:54 PM
whiteVLX's Avatar
Juice w/Attitude
I Beta tested the Juice/ Attitude combo my Y2K and it's great. The Beta didn't have the hot mode, but the production does. I don't have a trip computer so I mounted it in the spacer plate where the trip computer goes. It made for a very clean install and visibility is pretty good except for extremely bright days. But with all the alarms you can set up I'm finding that after the newness wore off I'm not looking at the gauges at all. The turbo timer feature is really cool too.
Old 04-03-2006, 11:49 PM
GlennRMK's Avatar
So, the production models fuel to 3200 or whatever like the DRAG Comp?
I was also thinking about mounting it to the clear cluster cover were Park, Drive etc would be if mine were an auto.
Also, you I'm assuming you can hook up like an EZ correct?
I have warranty till July, and I might weight till then to tap the pump wire.
I am also going to put in a clutch and injectors, so I might wait for the clutch for the higher power level anyways.
Old 04-04-2006, 02:11 PM
KLockliear's Avatar
They are out now. We have them in stock.
The drag or hot option is built-in. You have to download the form from Edge's website, fax it in and they will call or e-mail you a code to put into the Attitude that unlocks level 5 to the hot setting.
Old 04-04-2006, 07:30 PM
dingoo's Avatar
i ordered mine but i didnt see anything about fuel pressure monitoring, maybe i missed it. i think i read that it helps to have a angle drill to do the pyro install. anybody have any info on that??? hopefully picking it up tomorrow
Old 04-04-2006, 08:27 PM
mooseman's Avatar
Originally Posted by ratat98
So im going to be getting some money soon and im wondering if I want an Edge Comp, or an Edge Juice? I want more power, and lots more smoke...will the Juice still make the same smoke that the Comp will? I like the juice because it comes with the gauges display and I dont have gauges yet so it would be killing two birds with one stone...any thoughts?
I alpha tested the juice/attitude so Ive been running it for quite a while now with no troubles. The only update Ive had to have done is the hot (level six). IMO you cant go wrong with the juice/attitude.
Mooseman
Old 04-04-2006, 09:32 PM
Sea01Cummer's Avatar
Who is selling them???? Links anyone?????
Steve
Old 04-04-2006, 11:34 PM
whiteVLX's Avatar
I drilled mine with a 18V cordless Ryobi and had no need for an angle drill. Went real well, just went slow and used grease to pick up the chips.
Old 04-05-2006, 12:22 AM
ratat98's Avatar
Thanks for all the help everyone! I think ill go with the juice/attitude combo when i get around to it! It looks like it will be a pretty sweet setup
Old 04-05-2006, 01:01 AM
GlennRMK's Avatar
HP Upgrades
or
Source Automotive
Both of these guys have given me very good prices
Old 04-05-2006, 03:55 PM
ratat98's Avatar
One more question...does the Juice/Attitude combo come with all the hookups and censors, like pyro, fuel pressure etc. or are all those seperate buys?
Old 04-05-2006, 04:00 PM
seabee's Avatar
from every thing i have read and the salesmen that i have talked to its a full kit with all you need to put it on sensors and all .
Old 04-05-2006, 04:19 PM
GlennRMK's Avatar
Its a kit
I should be getting mine next week hopefully. Will find out for sure
And I will have to find a good place to mount it.
Old 04-05-2006, 10:17 PM
HP Upgrades's Avatar
Yes you get everything needed for the complete install. We have them in stock and have looked through the kits to verify the parts. Our understanding is that mounts are being manufactured as we speak, but we do not have any just yet. I think a little velcro would be fine for a while....At least it is with mine!
Old 04-05-2006, 10:20 PM
GlennRMK's Avatar
Does it come with that universal chrome mount?
I've seen it on a few Duramaxes.
Old 04-05-2006, 10:22 PM
whiteVLX's Avatar
If you call a piece of aluminum angle universal, well then yes it does.
Quick Reply: Comp or Juice?
