Comp HELP
Comp HELP
well i installed my comp today and tapped into the pump. but im scared i might have done the wrong wire because the instructions were kind of hard to understand and the picture did no good either. anyways, level 1 seems to be the same as level 5. it has a good punch to it now, but all the different levels seem to be the same power. could tapping the wrong wire do this or what could be wrong?
Yes, if the power levels are the same from 1-5 then there's a very good chance you tapped the wrong wire. YOu want the upper wire closest to the block. It's clear in the TST instructions here:
http://www.tstproducts.com/pdffiles/PMInstr6.pdf
see i did that wire first and it did the same thing. late last night, i went back in and tapped into the lower one closest to the block, but same as the other wire.
Edge has been having some issues with Version 8.0, what version is yours? Check the label on the bottom of the box. You should be able to send it in and have it updated for free. I have heard of some issues with the new 10.8 version unfortunately, specifically the cold start problem.
mine is the 10.8 version. I pulled it off my truck and installed it on a friends 2000 and it did the same thing. i called edge today and they told me to change my fuel filter... im sending it in tomorrow. its got to be the chip
MoreSmoke
01-07-2004 09:40 PM
James Lucas
14
08-29-2003 11:24 AM
hellotbone
07-12-2003 12:58 AM
hellotbone
18
05-16-2003 04:40 PM
