Comp Edge Boost?
Comp Edge Boost?
i have a comp edge box, only getting max 24 lbs boost on 5x5. afe air intake, when i hammer it i have 6 lbs fuel presssure, 15 at idle. i have a new lift pump. is that normal?? im not using the "J" hook wastegate bolt
What does your pyro say?
IMO the problem is that your wastegate opens up and even though you overpower it a bit you do not get the full boost you should get- I think blocking the wastegate isn't a too good idea, wastegating the turbo to around 30-35 psi is much better.
HTH
AlpineRAM
HTH
AlpineRAM
Registered
Originally Posted by CTD NUT
Why aren't you using the J hook? The Comp provides a large increase in additional fueling over stock and requires a corresponding increase in boost to match.....Power will be up and egt will be down if you use the J hook to stop the wastegate from opening. Even at your elevation, you should be able exceed 30 psi with the Comp on kill.
exactly, install the j hook. its why they gave it to you with the box
While running the boost elbow on mine, I can get upto 45 lbs of boost with the Comp box set on 5X5. I'm starting to think that I need to turn the boost back some. Hopefully that will contain my egts as I can reach 1200 pretty easy on a WOT run down the highway.
I have a question on this... I have a Banks Big Head waste gate and I can't get much past mid 20's without dropping to 3rd. but I don't see a place to use that elbow on my turbo??? I'm I missing some potential power?
well the "j" hook was not in the box, piers just gave it to me, i have heard mixed messages on to install it or not. i was told to not let the boost to go over 33 with my stock turbo. "anyone? is that true?" so i was worried. im green with all this, give me a toyota 4x4 to work on, in a snow storm in the dark with my shorts on, i can fix that. so ill install it. and lets see if the pyro will stay a little lower. it will hit 1400 no problem on hard accell.
ok i figured it out, installed it, now i get 33-34 no prob, wow what a difference, i hit 35 doing like 95 mph down the hwy. not normal driving.now i wonder if it will tow better. i still got the egt's up to 1400, but i was going up hill at 70 mph. it seemed to take longer to heat up.
Does anybody know much about the Big Head design... I have one on my truck and I'm having a hard time getting that much boost too. What's a "j-hook?" Just the boost elbow they give you?
HX35 on ebay, marine application, don't know if that would work....here it is
http://cgi.ebay.com/ebaymotors/holse...QQcmdZViewItem
