Comp Drag and clutch
With the purchase of an 02 H.O 6sp I am looking into the Drag Comp box. I like it for the fact that you can adjust it in the cab and you can turn it off and the truck will be stock. My buddy has an 01 just like mine and that is the only thing he has done to his truck is the Comp Drag Box and when the box is on 5 the truck will throw some pretty good smoke. My question is that will I need to beef up the clutch. This is the only upgrade that I plan on doing because I dont want problems I just want a little more power and to blow a little smoke on occasion. Any input would be appreciated as in other boxes also.
Thanks.
John
Thanks.
John
On the higher sub level settings (4-5) the truck puffs a little bit of smoke when hard on the throttle at low boost but clears up quickly when the boost climbs......on 5x5 there is a constant light haze @ WOT. The RV275's didn't add much smoke.
![Wink](https://www.dieseltruckresource.com/forums/images/icons/icon12.gif)
My clutch started slippin on just level 5, now it slips on occassion on level 3. Mine smokes on all levels. A little on one, A nice cloud on 3 and up! Ever since I put the stacks on I cant help but look in the rearview everytime I take off!
mx684
13
07-24-2007 07:52 PM
MoreSmoke
01-07-2004 09:40 PM
hellotbone
18
05-16-2003 04:40 PM
